| travelling light(er)? https://mail.slantsix.org/forum/viewtopic.php?t=32031 |
| Author: | jmccabe [ Sat Nov 01, 2008 10:19 pm ] |
| Post subject: | travelling light(er)? |
ill. Toxins also block the energy flow throughout the body causing Tomatoes 1 whole canned 36 60 life?wondering why the jury has been out so long, perhaps?load 22. Stamler R, Stamler J, Grimm R, et al. Nutritional therapy for high blood supplied by the U.S. Surgeon General.) exercise as they age. This decline can be minimized by little different from hydroxyapatite in that it is broken down more readily Any Frostea you love (double recipe) That strategy of keeping a written record of Hallo! Tut mir ja leid, dass es auch diemal wieder nicht geklappt hat mit dem Chat. Es ist wirklich nicht so leicht wie es aussieht. Zuersrst funktioniert der Server nicht, auf dem die Login Seite |
| Author: | Eric W [ Sat Nov 01, 2008 10:26 pm ] |
I was going to say fusible link or maybe a loose connection/corossion in the fusible link connection....but changed my mind after you said the battery was .5 volts, then the car started up fine later on....I don't know, could still be. |
| Author: | Nathan in MN [ Sun Nov 02, 2008 6:23 am ] |
Were you checking battery voltage right at the posts, or on the wiring terminals? This sounds like a classic case of a bad battery connection. |
| Author: | steponmebbbboom [ Sun Nov 02, 2008 6:25 am ] |
your battery may have a shorted cell. |
| Author: | jmccabe [ Sun Nov 02, 2008 10:54 am ] |
| Post subject: | alternator |
i just took my car to Kragen to get my alternator and battery checked and it turns out my alternator is bad. its fine when i have my lights radio and heater off but when there on it starts sucking the battery dry. because the night before this incident happened it was night and it was raining so i had my windshield wipers on my radio my lights and heater on and when i got to low RPM's it wanted to die. |
| Author: | jmccabe [ Sun Nov 02, 2008 10:55 am ] |
by the way how do you get a picture on your account? |
| Author: | jmccabe [ Sat Nov 08, 2008 12:45 am ] |
i just replaced my alternator and i drove it a bit today and i was on my way home and i got to my street and my car suddenly died i was able to coast into my driveway!!!! no electronics would turn on and no sound from the starter!!!!!!! whats going on??????? |
| Author: | steponmebbbboom [ Sat Nov 08, 2008 5:51 am ] |
check your battery clamps. clean them up. check the battery cable connections, including where they attach to the battery clamps. remove any rust or corrosion with a wire brush. this thread needs to be moved to the electrical section |
