| gauges https://mail.slantsix.org/forum/viewtopic.php?t=3217 |
| Author: | Byron Spence [ Fri Feb 08, 2002 11:23 am ] |
| Post subject: | gauges |
I was able to replace the panel voltage regulator, yet my gas gauge still reads about 1/8 of a tank. Is there something else that i should look for? How does the panel ground on a 68 dart? Byron byronspenc@hotmail.com |
| Author: | Doc. [ Fri Feb 08, 2002 11:59 am ] |
| Post subject: | Re: gauges |
: I was able to replace the panel voltage : regulator, yet my gas gauge still reads : about 1/8 of a tank. Is there something else : that i should look for? How does the panel : ground on a 68 dart? Byron What happens if you ground the fuel gauge wire back at the gas tank, this should make the gauge go to full. Does it do that? If so the problem is with the sending unit or float assy. inside the gas tank. DD 64 Dart Gas Gauge Thread |
