It is currently Tue Nov 18, 2025 6:46 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sat Feb 09, 2002 11:09 am
We're using the Clifford 268 cam along with the dual valve spring setup. For now, we've got a NOS shaft and a full det of NOS rockers. Do the stock adjusting screws hold well? I've been looking at the secrew/locknut sets in the Mopar performance catalog. Will the V8 mopar screws fit? Should I be considering them?
Gilly
tlg225ccr@aol.com
PostPosted: Sat Feb 09, 2002 5:42 pm
: We're using the Clifford 268 cam along with the
: dual valve spring setup. For now, we've got
: a NOS shaft and a full det of NOS rockers.
: Do the stock adjusting screws hold well?
: I've been looking at the secrew/locknut sets
: in the Mopar performance catalog. Will the
: V8 mopar screws fit? Should I be considering
: them?
: Thanks,
: Gilly
The stock ones should be just fine. This ain't no cheap V8 junk. The rockers are some of the most bulletproof parts of the Slant engine. I have never had troubles with rockers with any high-lift cams with big valve springs. I have about 30k on my 0.540" cam with fat springs and I adjust the rockers about every other oil change, but I'm usually spinning this thing to 6000 doing racing too...,
Cheers,
madsenl@its.caltech.edu
PostPosted: Sun Feb 10, 2002 7:53 am
: The stock ones should be just fine. This ain't
: no cheap V8 junk. The rockers are some of
: the most bulletproof parts of the Slant
: engine. I have never had troubles with
: rockers with any high-lift cams with big
: valve springs. I have about 30k on my
: 0.540" cam with fat springs and I
: adjust the rockers about every other oil
: change, but I'm usually spinning this thing
: to 6000 doing racing too...,
: Cheers,
: Lou
Thanks, Lou. Can't believe that I'm throwing rocks at Chevy, but changing the rocker arm adjusting nuts on the SB Chevy was one of the first mods I made when using a Mech lifter cam. I had a Duntov 30/30 cam in a 283 that wouldn't hold adjustment worth beans.
I have read that the SL6 valve train is good, but these rocker arms just "don't look hi-tech". That said, lets give it a go. Thanks for saving me the $$ on the adjusting screws.
Gilly
tlg225ccr@aol.com
PostPosted: Sun Feb 10, 2002 8:03 am
: Thanks, Lou. Can't believe that I'm throwing
: rocks at Chevy, but changing the rocker arm
: adjusting nuts on the SB Chevy was one of
: the first mods I made when using a Mech
: lifter cam. I had a Duntov 30/30 cam in a
: 283 that wouldn't hold adjustment worth
: beans.
GASP ! He said "small block", and "Chevy" on the /6 board!!!
: I have read that the SL6 valve train is good,
: but these rocker arms just "don't look
: hi-tech". That said, lets give it a go.
: Thanks for saving me the $$ on the adjusting
: screws.
Gilly, you're absolutly right, they do look rather lo-tech, but that's part of the beauty of the engine. Two-piece, riveted stamped steel rockers, but yet, they will go 200,000+ miles without failure. The adj'r screw should be somewhat stiff to turn in the rocker arm. If it's only finger-tight stiff, I would suggest going with a different rocker arm. Doc Dodge might have a bit more data on this.
Roger
GTS225@aol.com
PostPosted: Sun Feb 10, 2002 12:12 pm
: screws.
: Gilly
The only things I ever do to the stock SL6 rocker arms is:
-Make sure they are oiling out the tips.
-Make sure the tips are centered over the valve stem.
-On real stiff Valve Spring set-ups, I put a small spot weld at the seam, bottom side of the rocker arm, right where the screw goes through, this keep the screw threat hole from spreading open under heavy loads.
