| Where is volt limiter on 67 panel? https://mail.slantsix.org/forum/viewtopic.php?t=33319 |
| Author: | RDJ [ Wed Jan 14, 2009 5:42 pm ] |
| Post subject: | Where is volt limiter on 67 panel? |
I pulled the dash/gauge panel on my 67 Barracuda, but I don't see the voltage limiter on the back side (like my 73 Dart three prong VL). Is there one? If so, where is it located? |
| Author: | oo3 [ Wed Jan 14, 2009 10:03 pm ] |
it may be in the gas gauge like my 66 a100 - if not someone will have the answer soon - oo3 |
| Author: | bigslant6fan [ Sun Jan 18, 2009 7:08 am ] |
| Post subject: | vr |
I know for certain it is in the fuel gauge. |
| Author: | RDJ [ Tue Jan 20, 2009 10:08 pm ] |
| Post subject: | Re: vr |
Quote: I know for certain it is in the fuel gauge.
Can this be replaced by a solid state unit? I have my gauge panel apart right now, and the gauges are crimped together. Can the gas gauge be taken apart without ruining it?
| Author: | SlantSixDan [ Tue Jan 20, 2009 10:38 pm ] |
Answer is yes, but that's not relevant to your situation; 1965 was the last year the voltage limiter was built into the gauge on A-bodies. If you haven't found it on your '67, it's because it's absent or you haven't spotted it yet. It is the external plug-in type. |
| Author: | 65 dartman [ Wed Jan 21, 2009 1:49 pm ] |
| Post subject: | Re: Where is volt limiter on 67 panel? |
Quote: I pulled the dash/gauge panel on my 67 Barracuda, but I don't see the voltage limiter on the back side (like my 73 Dart three prong VL). Is there one? If so, where is it located?
This link SSDan posted sounds like a great upgrade to protect the gauges. I'd venture to say this would affect you as A Body rallye dashes (such as you have) have the limiter incorporated with the gas gauge.
| Author: | RDJ [ Sun Jan 25, 2009 1:25 am ] |
Thanks for the link. My fuel gauge has the three bolts coming out as pictured in the link, and there are no slots for a VL to plug into. I may have to try the solid state one. I don't really want to pull the dash again if I don't have to. |
| Author: | bigslant6fan [ Sun Jan 25, 2009 8:51 am ] |
| Post subject: | gauges |
I did my 68 cuda 6 years ago.pry apart the gauge,removed the vr with a dremal tool,and put a 7805 regulator mounted to the back of the pot metal dash. Mopar action had an articule on this in aug 2000 |
