It is currently Tue Nov 18, 2025 1:49 am
 Post subject: Turbo question.
PostPosted: Sun Mar 10, 2002 4:17 am
Can a turbocharger be mounted with axis 60 degrees
upward relative to the plane of the crankshaft? Seems like there is no reason why not. Pressurized oil feed to bearing.
I pickup two mopar garret turbo's today. They could mount over inverted stock manifolds at about 60 (more or less). and bolt simply with an simple adapter it now appears. The mopar stock exhaust housing could be retained and would aim nicely toward the rear in this configuration.
I'm having fun.
Grabbed a ford turbo also. Almost grabbed two volvo turbo deisel turbos's as well, but wanted to run home, watch the kids soccer game, and then play awhile in the shop.
I did grab the ford intercooler system. It's really neat. Mounts flat under the hood. And has a scoop to catch and direct air into the cooler.
I appreciate any more suggestions.
rosendalemj@yahoo.com
 Post subject: Re: Turbo question.
PostPosted: Sun Mar 10, 2002 6:00 am
If I am picturing this right, then the intake side would be below the exhaust side of the turbo? This would cause the oil to lay against the inner seal and would start to leak. now you can loosen the bolt on the turbo and spin the housing almost any way oyu want as long as the waste gate actuator can line up so that it works the right way.
andrew wagner
: Can a turbocharger be mounted with axis 60
: degrees
: upward relative to the plane of the crankshaft?
: Seems like there is no reason why not.
: Pressurized oil feed to bearing.
: I pickup two mopar garret turbo's today. They
: could mount over inverted stock manifolds at
: about 60 (more or less). and bolt simply
: with an simple adapter it now appears. The
: mopar stock exhaust housing could be
: retained and would aim nicely toward the
: rear in this configuration.
: I'm having fun.
: Grabbed a ford turbo also. Almost grabbed two
: volvo turbo deisel turbos's as well, but
: wanted to run home, watch the kids soccer
: game, and then play awhile in the shop.
: I did grab the ford intercooler system. It's
: really neat. Mounts flat under the hood. And
: has a scoop to catch and direct air into the
: cooler.
: I appreciate any more suggestions.
