It is currently Tue Nov 18, 2025 7:45 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Slant Six
PostPosted: Tue Mar 19, 2002 11:59 am
I have just a few questions that I really need help with.
1. Will the flywheel off a 225 Slant Six with a Steel Crank interchange with a Cast Crank?
2. Were either the steel crank or cast crank 225 Slant Six's externally balanced?
Thanks
lemhitnd@ida.net
 Post subject: Re: Slant Six Questions
PostPosted: Tue Mar 19, 2002 4:47 pm
: I have just a few questions that I really need
: help with.
: 1. Will the flywheel off a 225 Slant Six with a
: Steel Crank interchange with a Cast Crank?
Yes, But some of the later flywheels are heaver, all are made or cast iron waiting to "blow-up" if abused.
: 2. Were either the steel crank or cast crank
: 225 Slant Six's externally balanced?
No, But the factory balance job is "suspect".
