more info for your best guess
https://mail.slantsix.org/forum/viewtopic.php?t=3377
Author:  Jerry [ Wed Mar 20, 2002 5:42 pm ]
Post subject:  more info for your best guess
58.5 cc head, 27cc above piston, gray felpro 38 thou? thick perma torque head gasket.
What is my compression ratio?
Jerry
roxnjer@aol.com
Author:  Doctor Dodge (Doug Dutra) [ Wed Mar 20, 2002 8:44 pm ]
Post subject:  Re: best guess #2
: 58.5 cc head, 27cc above piston, gray felpro 38
: thou? thick perma torque head gasket.
: What is my compression ratio?
: Jerry
Most head gaskets are .045, some are .038 and others .020 (steel shim type)
58.5 + 27 + 6 (.038) = 91.5 cc
On a .030 o/s "228" CID that gets you a 7.85 c/r
(If these are actual readings, mill the head or use a Turbo)
A Compression Worksheet example
