| Doug...please look & advise https://mail.slantsix.org/forum/viewtopic.php?t=3423 |
| Author: | GTS225 [ Tue Apr 02, 2002 10:56 am ] |
| Post subject: | Doug...please look & advise |
Found this cam on E-bay. Think it'd make a good turbo/blower motor bumpstick with that short overlap. Would like your opinion. Item number.... 1818138576 Sorry, still haven't got the link thing figured out. Roger GTS225@aol.com |
| Author: | Doc. [ Tue Apr 02, 2002 12:28 pm ] |
| Post subject: | Re: ebay SL6 Cam |
: Found this cam on E-bay. Think it'd make a good : turbo/blower motor bumpstick with that short : overlap. Would like your opinion. : : Item number.... 1818138576 : : Sorry, still haven't got the link thing figured : out. The link is as easy as a "copy - paste" into the Optional Link URL box below and name it with a title, You can also simple cut and paste the address right into the message like this: <A HREF="http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1818138576&r=0&t=0">http://cgi.ebay.com/ebaymotors/ws/ebayISAPI.dll?ViewItem&item=1818138576&r=0&t=0</A> Anyway, that MP cam is pretty aggressive, has a 76 degree overlap and .528 lift, also note the loose lash settings. I would say it is too much for a turbo set-up. DD ebay SL6 Cam Link |
| Author: | mark dingbaum [ Tue Apr 02, 2002 1:49 pm ] |
| Post subject: | Re: Doug...please look & advise |
Hey Roger, I 'think' this is the same cam that I was running in my dragster...oil pump/dist gear has some broken teeth. If you want the cam to play with/measure on, let me know and you can have it. I did not measure the cam, but the previous owner said the cam was the MP 284 .528 cam. regards, mark mldingba@rockwellcollins.com |
| Author: | dschumers [ Tue Apr 02, 2002 3:21 pm ] |
Man, Koller must have found a truckload of those cams! Dennis slantzilla@excite.com |
| Author: | Doc. [ Tue Apr 02, 2002 5:49 pm ] |
| Post subject: | Re: Advise, How did it run, Lumpy Idle? |
How did the cam run before the O.P. gear stripped? What was the RPM "sweet spot"? DD Quote:
: Hey Roger, : I 'think' this is the same cam that I was : running in my dragster...oil pump/dist gear : has some broken teeth. If you want the cam : to play with/measure on, let me know and you : can have it. : : I did not measure the cam, but the previous : owner said the cam was the MP 284 .528 cam. : : regards, : mark |
| Author: | GTS225 [ Wed Apr 03, 2002 7:08 am ] |
: The link is as easy as a "copy - paste" into the Optional Link URL box below and name it with a title, You can also simple cut and paste the address right into the message like this:
************************************************* DOH !! Some of the simplest things trip me up at times. I've been trying to cut/paste into the text box and keep overlooking the link box. : : Anyway, that MP cam is pretty aggressive, has a : 76 degree overlap and .528 lift, also note : the loose lash settings. I would say it is : too much for a turbo set-up. DD ************************************************** Sheeesh! I musta been really tired to think it would have been ok for a pressure motor.......I gotta stop this 3rd shift stuff and find me a day job. Thanks for the advise, Doug Roger GTS225@aol.com |
| Author: | mark dingbaum [ Wed Apr 03, 2002 11:40 am ] |
| Post subject: | Ran ok, see txt |
Hi Doc, Best time of 12.06 @ 111. 1.9 60 ft times. In a 1550 lb dragster (with driver), 4000+ stall powerglide, 4.56 gears 10.5x30 tires. 390 Holley vac sec on Offy, 8.5ish compression. MP ported head (1.7/1.44). I wouldn't call the idle 'lumpy', but I let it idle around 900 to 1000 rpm. It would have probably idled down to around 750 and might have sounded lumpy then. I did not notice a real sweet spot, but then I was probably 'on the cam' before the converter stalled also. It seemed to pull good to my 6,000 rpm shift point. I felt the car should be much faster than it was, but the compression was a lot lower than I had been told, and I never really got around to tuning it much before the oil pump gear stripped. I'm having a new engine built now at J&M, this will use the same head but have around 12.5 compression with a quench style piston similar to your previous effort. I'm hoping for low 11s/high 10s. I hope this answers most of your questions. regards, mark mldingba@rockwellcollins.com |
| Author: | WhaleMstr [ Thu Apr 04, 2002 10:51 am ] |
| Post subject: | Re: ebay SL6 Cam work in van? |
Would a cam like that work in my van rebuild? Just curious, it's got an auto in it - but I am thinking of putting the built motor in my 108 van now and it's got a 3 on the tree. Anyway, Thanks for any responses, Talk at ya later, Dan WhaleMstr's Web Garbage! gramma@dm-tech.net |
