It is currently Mon Nov 17, 2025 11:12 am
PostPosted: Sun Apr 07, 2002 10:24 am
I'm thinking of porting and polishing the head on my car. Would this benifit any performance aspects on a daily driver? If so do you have any specs so I can take to the machine shop.
bigman6969170335@aol.com
PostPosted: Sun Apr 07, 2002 10:42 am
: I'm thinking of porting and polishing the head
: on my car. Would this benifit any
: performance aspects on a daily driver? If so
: do you have any specs so I can take to the
: machine shop.
Just grind-out the sharp edge roght under the valve seat, right where the machined angle meets the rough "as cast" port surface. Grind-off any other rough edges or bumps you see and you are set.
