| Re: 2X1 intake manifold https://mail.slantsix.org/forum/viewtopic.php?t=3440 |
| Author: | Dan [ Sun Apr 07, 2002 8:12 am ] |
| Post subject: | Re: 2X1 intake manifold |
Thought I was doing something new, well different set up anyway. I used the original intake and exhaust manifolds and two Holley single barrels. http://hometown.aol.com/slantedsix225/carbs_index.html SlantedSix225@aol.com |
| Author: | Doctor Dodge (Doug Dutra) [ Sun Apr 07, 2002 9:55 am ] |
: Thought I was doing something new, well : different set up anyway. I used the original : intake and exhaust manifolds and two Holley : single barrels. That *is* different. Did you make the adaptor and air cleaner "hat"? I think a small Turbo would be a good next step, that would help the flow though the single opening 1 BBL manifold. DD |
| Author: | Dan [ Sun Apr 07, 2002 11:23 am ] |
: That *is* different. : Did you make the adaptor and air cleaner : "hat"? : I think a small Turbo would be a good next : step, that would help the flow though the : single opening 1 BBL manifold. : DD Yes I made them. you can see the mocks I used to make the castings on this page on the site I'm working on to show the install in progress. I'm going to put in the IHI turbo off of a Subaru 1.9 L. as soon as I get the rebuild kit I ordered from Turbo City. By the way Doug, those are the carbs I got from you. http://hometown.aol.com/slantedsix225/enginecompartment.html SlantedSix225@aol.com |
