It is currently Tue Nov 18, 2025 4:43 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
PostPosted: Sun Apr 07, 2002 8:12 pm
What years did the A bodies have the non-od 4 speed? I think '76 was the first year of the OD 4 speed. Right? I found a '75 Duster for parts, and would like to know what 4 speed it has before buying. Thanks.
PostPosted: Sun Apr 07, 2002 10:04 pm
: What years did the A bodies have the non-od 4
: speed? I think '76 was the first year of the
: OD 4 speed. Right? I found a '75 Duster for
: parts, and would like to know what 4 speed
: it has before buying. Thanks.
1964(63?)-1974 should all be A-833 standards (direct 4th gear, 1964-1966 should have the 3.09 1st gear too)
1975-1987 should all be A-833OD units, I just got an iron cased A-833OD off of ebay it's from a 1975 Dart with 3.23 rear gears...
good luck,
res0aus2@verizon.net
PostPosted: Mon Apr 08, 2002 9:24 pm
: 1964(63?)-1974 should all be A-833 standards
: (direct 4th gear, 1964-1966 should have the
: 3.09 1st gear too)
: 1975-1987 should all be A-833OD units, I just
: got an iron cased A-833OD off of ebay it's
: from a 1975 Dart with 3.23 rear gears...
: good luck,
: -D.Idiot
hey I wondering if that ebay tranny was a direct fourth, I almost bid against you also thought about offering to buy it off you later.Incidentialy according to the people I bought my 4spd from in woodburn it came out of a 63 signet and that was the first year a 4spd was offered.looking for another for back up. Bruce
PostPosted: Mon Apr 08, 2002 9:54 pm
: hey I wondering if that ebay tranny was a
: direct fourth, I almost bid against you also
: thought about offering to buy it off you
: later.Incidentialy according to the people I
: bought my 4spd from in woodburn it came out
: of a 63 signet and that was the first year a
: 4spd was offered.looking for another for
: back up. Bruce
I broke it open and she's an OD tranny, the vin stamped on the pad started with a '5' (1975), she was a good buy, the previous owner used oil not ATF so the guts are all minty (no chipped gears, synchros look like the day they were put in...)
I think I'm going to pull the casing and tail shaft and replace them with the aluminum parts I have (like you I need a good spare for my Feather Duster).
I'll keep an eye out, does yours require the ball and trunion?
PostPosted: Tue Apr 09, 2002 12:35 pm
: I broke it open and she's an OD tranny, the vin
: stamped on the pad started with a '5'
: (1975), she was a good buy, the previous
: owner used oil not ATF so the guts are all
: minty (no chipped gears, synchros look like
: the day they were put in...)
: I think I'm going to pull the casing and tail
: shaft and replace them with the aluminum
: parts I have (like you I need a good spare
: for my Feather Duster).
: I'll keep an eye out, does yours require the
: ball and trunion?
: -D.Idiot
mine had aball and trunion but I was able too switch( no machineing with the yoke of a78 dodge pickup top loader Bruce
magicalbus@hotmail.co
