It is currently Tue Nov 18, 2025 8:38 pm
 Post subject: Mag Pickup Questions..
PostPosted: Sun Apr 28, 2002 1:15 pm
hello all...
well on my 87Ram i'm converting to the old style electronics...well i got a wiring harness out of a Ram Charger and a dist out of a labaron...i need to know if the dist gets power or gives power when ignition is on...also i have a orange and black/blue connecting wire and on the other harness i have a pink, white (orangish), brown/gray and a solid brown...can anyone tell me which wires are the correct ones to hook my mag pickup wires into??? or how to check??
Justin
http://geocities.com/hi_po_slantsix/index.htm
slantsickness@hotmail.com
PostPosted: Mon Apr 29, 2002 6:40 pm
: hello all...
: well on my 87Ram i'm converting to the old
: style electronics...well i got a wiring
: harness out of a Ram Charger and a dist out
: of a labaron...i need to know if the dist
: gets power or gives power when ignition is
: on...also i have a orange and black/blue
: connecting wire and on the other harness i
: have a pink, white (orangish), brown/gray
: and a solid brown...can anyone tell me which
: wires are the correct ones to hook my mag
: pickup wires into??? or how to check??
: Justin
looking at ecu box with capacitor on left side and plug on right side the 2 bottom pins go to distributor.
