| Spark advance question https://mail.slantsix.org/forum/viewtopic.php?t=3583 |
| Author: | Jerry [ Tue May 07, 2002 8:24 pm ] |
| Post subject: | Spark advance question |
My total advance of 30* is made up of 8* initial and 22* centrifugal in the dist. My question is, would a combo of 4* initial and 26* centrifugal give me the same results? How far from TDC can you stray before you want to make a change? roxnjer@aol.com |
| Author: | Dart270 [ Wed May 08, 2002 6:37 am ] |
| Post subject: | Re: Spark advance question |
: My total advance of 30* is made up of 8* : initial and 22* centrifugal in the dist. My : question is, would a combo of 4* initial and : 26* centrifugal give me the same results? : How far from TDC can you stray before you : want to make a change? In general, the second choice will give you slightly worse throttle response and idle (especially with a hotter cam/comp), and similar total power. The first would be my preference, and I usually run more initial advance (at least 10 deg) on my motors. Lou |
| Author: | Doc. [ Wed May 08, 2002 10:07 am ] |
: In general, the second choice will give you : slightly worse throttle response and idle : (especially with a hotter cam/comp), and : similar total power. The first would be my : preference, and I usually run more initial : advance (at least 10 deg) on my motors. : Lou I'm with Lou, I set my initial timming first to find the place where the idle and throttle response is good with out shut-down "run-on". Once I find an initial setting I like, set the mechanical to get the needed total. The last step is selection and setting of the vacuum advance pod and spring rate. DD |
