It is currently Mon Nov 17, 2025 8:50 am
PostPosted: Sat May 25, 2002 12:16 pm
On my "Screamin' Six" engine, the Offenhauser intake consistently shows #5 running lean, the other cylinders are more or less even. #6 is always the richest.
I've read in the past about epoxying in popsicle sticks to alter the flow in the manifold, and while at work this past week, built up a good supply of ice cream sticks from convenience stores. (I try not to work TOO hard!)
Any particular kind of epoxy to use for continuous contact with gasoline? Can this be a permanent modification? Any ideas on how to best position the sticks (and what dimensions) to add fuel to #5? I have my own ideas but would like some confirmation before proceeding. Thanks.
PostPosted: Sun May 26, 2002 4:05 pm
: On my "Screamin' Six" engine, the
: Offenhauser intake consistently shows #5
: running lean, the other cylinders are more
: or less even. #6 is always the richest.
: I've read in the past about epoxying in
: popsicle sticks to alter the flow in the
: manifold, and while at work this past week,
: built up a good supply of ice cream sticks
: from convenience stores. (I try not to work
: TOO hard!)
: Any particular kind of epoxy to use for
: continuous contact with gasoline? Can this
: be a permanent modification? Any ideas on
: how to best position the sticks (and what
: dimensions) to add fuel to #5? I have my own
: ideas but would like some confirmation
: before proceeding. Thanks.
I would do some grinding inside the manifold first. Open-up the entry to runner #5. Grind the divider walls and the floor to direct mixture into that runner. I used a carbide burr on the end of a flex shaft and guided by a handle to get to those tuff to reach spots.
Next try some staggered jetting in the carb. After that comes the epoxied-in dams. Epoxy dams are temporary only, once you get things working right, slot through the manifold wall and insert some alm. "wedges" then weld-up the seam for a permanent fix.
PostPosted: Tue May 28, 2002 11:41 am
: I would do some grinding inside the manifold
: first. Open-up the entry to runner #5. Grind
: the divider walls and the floor to direct
: mixture into that runner. I used a carbide
: burr on the end of a flex shaft and guided
: by a handle to get to those tuff to reach
: spots.
: Next try some staggered jetting in the carb.
: After that comes the epoxied-in dams. Epoxy
: dams are temporary only, once you get things
: working right, slot through the manifold
: wall and insert some alm. "wedges"
: then weld-up the seam for a permanent fix.
: DD
We are lucky on this one, Chrysler already did the work. Check out <A HREF="http://www.speakeasy.org/~kesteb/dart/d ... bs.html</A> .
klesteb@aol.com
Users browsing this forum: Bing [Bot] and 35 guests
