It is currently Tue Nov 18, 2025 5:40 am
PostPosted: Fri Aug 08, 2014 8:49 am
Can A Fel-Pro or Permaseal AP 210 Be run on a N/A 14:1 Engine?
Or is it time for Copper?
Just Curious.
PostPosted: Fri Aug 08, 2014 9:51 am
Car Model: 64 Valiant
It's time for copper and O-ringing at this point. With only 4 bolts per cylinder working against you, composition style head gaskets are futile.
PostPosted: Fri Aug 08, 2014 10:06 am
I only went for 13:1 on the 170 I built for Bonneville and I used copper with o-rings.
PostPosted: Fri Aug 08, 2014 10:11 am
Any time you get above 12-1 on a Slant you are flirting with disaster on standard head gaskets, even with studs.
Charlie keeps some copper gaskets I believe. Jim Cox may have some too.
PostPosted: Fri Aug 08, 2014 10:21 am
I agree copper is going to be the reliable solution. Permaseal with an 0-ring might do it, but likely not long term.
