| Edelbrock sideways...and report on my mods.. https://mail.slantsix.org/forum/viewtopic.php?t=3732 |
| Author: | CrAlt [ Thu Jun 06, 2002 10:37 pm ] |
| Post subject: | Edelbrock sideways...and report on my mods.. |
Do the edelbrock 500CFM 4bbl's work fine sideways? I had a issue with the holley 390 but setting the float high fixed it. If there is a issue whats the fix? I know zero about how these edel's work... I kicked my cam 4deg up with the mr gasket advance bushings...seems to have done good. I seem to have a little more low end grunt and my idle is more choppy and defined. I can also idle it down to 500rpm in gear now. My ISKY cam is on 109deg centerline if i remember right so is it now set at 105deg? I still dont have all the theary down pat... Also had the MP oversized valves put in. My machinest is a cool guy and since my head took longer then he said he back cut the valves 30 and took care of a step i had in the head bowls for free... He says the valves are "pro-flow" or something and between that and the fixing the step (I spent hours porting the head before and missed that.shows how much i know) I should see more topend power... He was right, the car charges hard now Now I have to make up my mind on 3.91's or 4.11's. cralt@optonline.net |
| Author: | Dart270 [ Tue Jun 18, 2002 1:26 pm ] |
| Post subject: | Re: Edelbrock sideways...and report on my mods.. |
: Do the edelbrock 500CFM 4bbl's work fine : sideways? : I had a issue with the holley 390 but setting : the float high fixed it. If there is a issue : whats the fix? I know zero about how these : edel's work... : : I kicked my cam 4deg up with the mr gasket : advance bushings...seems to have done good. : I seem to have a little more low end grunt : and my idle is more choppy and defined. I : can also idle it down to 500rpm in gear now. : My ISKY cam is on 109deg centerline if i : remember right so is it now set at 105deg? I : still dont have all the theary down pat... : : Also had the MP oversized valves put in. My : machinest is a cool guy and since my head : took longer then he said he back cut the : valves 30 and took care of a step i had in : the head bowls for free... He says the : valves are "pro-flow" or something : and between that and the fixing the step (I : spent hours porting the head before and : missed that.shows how much i know) I should : see more topend power... He was right, the : car charges hard now : : Now I have to make up my mind on 3.91's or : 4.11's. Sounds like great progress. I have the Edel 500 on w/ primaries toward the fender and it's the best way to go for a street/strip car. For pure drag it doesn't really matter, but driveability is better w/ it sideways. Lou |
