what distributor for 82
https://mail.slantsix.org/forum/viewtopic.php?t=3736
Author:  John Johnson [ Fri Jun 07, 2002 10:19 pm ]
Post subject:  what distributor for 82
I am replacing a 1970 SL6 198 with a 1982 225 in
a Duster, found my distributor would not fit. What
years of Dist. will fit on a 82 slant six? Thanks.
jhnjohnson@seanet.com
Author:  chrisG [ Wed Jun 12, 2002 1:14 pm ]
Post subject:  Re: what distributor for 82
: I am replacing a 1970 SL6 198 with a 1982 225
: in
: a Duster, found my distributor would not fit.
: What
: years of Dist. will fit on a 82 slant six?
: Thanks.
Any slant distributor should fit. The 82 came with the lean burn dizzy, but you can swap it with an earlier points or electronic distributor.
Author:  John Johnson [ Wed Jun 12, 2002 10:45 pm ]
: Any slant distributor should fit. The 82 came
: with the lean burn dizzy, but you can swap
: it with an earlier points or electronic
: distributor.
The shaft on the 70 dist.is slightly larger than
the hole in the block, I think I will just go
to a bone yard and pick up a newer piece,my sport
satellite is eating up all my fun money in gas,
it's time to get my sl6 on the road again.
