It is currently Mon Nov 17, 2025 11:00 am
 Post subject: what distributor for 82
PostPosted: Fri Jun 07, 2002 10:19 pm
I am replacing a 1970 SL6 198 with a 1982 225 in
a Duster, found my distributor would not fit. What
years of Dist. will fit on a 82 slant six? Thanks.
jhnjohnson@seanet.com
PostPosted: Wed Jun 12, 2002 1:14 pm
: I am replacing a 1970 SL6 198 with a 1982 225
: in
: a Duster, found my distributor would not fit.
: What
: years of Dist. will fit on a 82 slant six?
: Thanks.
Any slant distributor should fit. The 82 came with the lean burn dizzy, but you can swap it with an earlier points or electronic distributor.
PostPosted: Wed Jun 12, 2002 10:45 pm
: Any slant distributor should fit. The 82 came
: with the lean burn dizzy, but you can swap
: it with an earlier points or electronic
: distributor.
The shaft on the 70 dist.is slightly larger than
the hole in the block, I think I will just go
to a bone yard and pick up a newer piece,my sport
satellite is eating up all my fun money in gas,
it's time to get my sl6 on the road again.
Users browsing this forum: Google [Bot] and 16 guests
