It is currently Mon Nov 17, 2025 11:11 pm
PostPosted: Thu Jun 06, 2002 10:37 pm
Do the edelbrock 500CFM 4bbl's work fine sideways?
I had a issue with the holley 390 but setting the float high fixed it. If there is a issue whats the fix? I know zero about how these edel's work...
I kicked my cam 4deg up with the mr gasket advance bushings...seems to have done good. I seem to have a little more low end grunt and my idle is more choppy and defined. I can also idle it down to 500rpm in gear now. My ISKY cam is on 109deg centerline if i remember right so is it now set at 105deg? I still dont have all the theary down pat...
Also had the MP oversized valves put in. My machinest is a cool guy and since my head took longer then he said he back cut the valves 30 and took care of a step i had in the head bowls for free... He says the valves are "pro-flow" or something and between that and the fixing the step (I spent hours porting the head before and missed that.shows how much i know) I should see more topend power... He was right, the car charges hard now :)
Now I have to make up my mind on 3.91's or 4.11's.
cralt@optonline.net
PostPosted: Tue Jun 18, 2002 1:26 pm
: Do the edelbrock 500CFM 4bbl's work fine
: sideways?
: I had a issue with the holley 390 but setting
: the float high fixed it. If there is a issue
: whats the fix? I know zero about how these
: edel's work...
: I kicked my cam 4deg up with the mr gasket
: advance bushings...seems to have done good.
: I seem to have a little more low end grunt
: and my idle is more choppy and defined. I
: can also idle it down to 500rpm in gear now.
: My ISKY cam is on 109deg centerline if i
: remember right so is it now set at 105deg? I
: still dont have all the theary down pat...
: Also had the MP oversized valves put in. My
: machinest is a cool guy and since my head
: took longer then he said he back cut the
: valves 30 and took care of a step i had in
: the head bowls for free... He says the
: valves are "pro-flow" or something
: and between that and the fixing the step (I
: spent hours porting the head before and
: missed that.shows how much i know) I should
: see more topend power... He was right, the
: car charges hard now :)
: Now I have to make up my mind on 3.91's or
: 4.11's.
Sounds like great progress. I have the Edel 500 on w/ primaries toward the fender and it's the best way to go for a street/strip car. For pure drag it doesn't really matter, but driveability is better w/ it sideways.
Users browsing this forum: Bing [Bot], Google [Bot] and 12 guests
