| converter https://mail.slantsix.org/forum/viewtopic.php?t=3794 |
| Author: | hemidart1 [ Thu Jun 20, 2002 3:46 pm ] |
| Post subject: | converter |
HELP, I'VE JUST GOT MY SECOND CONVERTER FROM MOPAQR PERFORMANCE THAT DOESN'T FIT. I HAVE A '67 DART WITH A 904. I ORDERED A 2500 STAHL FOR A 904 BUT THE THING DOESN'T FIT INTO THE CRANK(THE FIRST ONE THEY SENT WAS A LOCK-UP PUT IN THE WRONG BOX). ANY HELP WOULD BE GREATLY APPRECIATED. alandnicole@shaw.ca |
| Author: | hemidart1 [ Thu Jun 20, 2002 4:12 pm ] |
| Post subject: | Re: converter |
: TO RESPOND TO MY OWN PROBLEM, THE CRANK JOURNAL SIZE CHANGED IN LATE '67 OR '68. BUT THAT MEANS I STILL NEED A CONVERTER, CAUSE I'M NOT CHANGING THE CRANK!
| Author: | Dart270 [ Fri Jun 21, 2002 6:41 am ] |
: HELP, I'VE JUST GOT MY SECOND CONVERTER FROM : MOPAQR PERFORMANCE THAT DOESN'T FIT. I HAVE : A '67 DART WITH A 904. I ORDERED A 2500 : STAHL FOR A 904 BUT THE THING DOESN'T FIT : INTO THE CRANK(THE FIRST ONE THEY SENT WAS A : LOCK-UP PUT IN THE WRONG BOX). ANY HELP : WOULD BE GREATLY APPRECIATED. You will need a custom unit, or at least one with the small snout. I think Chad has one for sale, or you can order one from a place like Midwest converters. Lou |
| Author: | elam [ Fri Jun 21, 2002 7:38 pm ] |
: You will need a custom unit, or at least one : with the small snout. I think Chad has one : for sale, or you can order one from a place : like Midwest converters. : : Lou I just ordered one from midwest talked to the owner Dennis he was very helpful ran my whole setup through his computer to build me the right converter. I think There the easyest people to deal with i've seen. melam@nxs.net |
| Author: | CRANKSNAPPER [ Fri Nov 01, 2019 3:06 pm ] |
'67 -'68 TRANSITION YEAR: THE HUB FOR( THE '67 & EARLIER) CONVERTER IS AN 1/8TH INCH SMALLER THAN NEWER CRANKS. USE A RING TO COMPENSATE FOR DIFFERENCE BY HAVING A MACHINE SHOP ZING ONE FOR YOU. TAKE A MEASUREMENT FROM HUB & SHAFT HOLE AND YOU ARE IN BUSINESS !! |
