It is currently Tue Nov 18, 2025 3:36 am
 Post subject: angle-milling?
PostPosted: Thu Jun 27, 2002 5:12 pm
I know this was a std thing to do with small block heads(chev, ford and mopars) a few years ago, but what is the lowdown on angle milling a sl/6 head? Has anybody tried it? How did it work? Are there any drawbacks? How much of an angle? Is it worth the trouble?
fglmopar@aol.com
 Post subject: Re: angle-milling?
PostPosted: Fri Jun 28, 2002 9:39 pm
: I know this was a std thing to do with small
: block heads(chev, ford and mopars) a few
: years ago, but what is the lowdown on angle
: milling a sl/6 head? Has anybody tried it?
: How did it work? Are there any drawbacks?
: How much of an angle? Is it worth the
: trouble?
I have angle milled one head, took .100 off the spark plug side and about .020 off the manifold side. The head bolt holes would bend the bolt over to the side a little so I ground a little at the tops and the carb mounting was no longer flat, I did not find any real performance advantage so I never did any other heads like that.
Users browsing this forum: Bing [Bot], Google [Bot] and 23 guests
