It is currently Thu Nov 20, 2025 4:17 am
PostPosted: Sun Dec 20, 2009 5:06 pm
'68 Dart column shift manual steering- needs the column restored..
It clicks, it pops, it rings, it's doing everything wrong however it does steer the car just fine. What parts need to be replaced on this thing when it comes apart shortly. part #s / ideas ?
68 dart -4 doors with house paint, dents, satellite radio, and no rust
67 coronet -4 doors, quarter million miles, currently retired and growing older in the yard
73 charger -2 doors big block car, prowls phx in winter, sits inside during summer
PostPosted: Mon Dec 21, 2009 11:25 am
I've reconditioned a number of '65-77 columns for Tidewater Mopar Club giveaway cars; in nearly every case, the coupler between the steering box and the column was broken. Once the support ring at the bottom of the column was broken, but I've never had a problem with the bearings up inside the column itself. It's quite likely that debris from the turn signal switch and elsewhere have fallen inside and are binding.
The only speciality tools I needed was a steering wheel puller, a lock plate depressor, and snap rings. I'd consider getting a special boot to replace the coupler cover - I've found them a bear to get back on.
