Not idle on holley 1920
https://mail.slantsix.org/forum/viewtopic.php?t=38410
Page 1 of 1
Author:  SL6 CHILE [ Fri Dec 25, 2009 2:37 pm ]
Post subject:  Not idle on holley 1920
Hi guys, merry christmas for alls! Not idle on holley 1920, but if i close the idle air bleed the idle comeback. This problem is not permanent.
Author:  SlantSixDan [ Fri Dec 25, 2009 2:51 pm ]
Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
Author:  SL6 CHILE [ Fri Dec 25, 2009 3:06 pm ]
Thanks Dan. The carburetor was a rebuild, but the idle system not working. This carburetor it´s very easy to rebuild, i dont understand the problem. The problem is not permanent and the main metering system works very well..
Author:  SL6 CHILE [ Fri Dec 25, 2009 4:32 pm ]
Any idea, please
Author:  SlantSixDan [ Fri Dec 25, 2009 5:01 pm ]
Transient problems like this suggest there's dirt or corrosion in some of the very small idle passages in your carb. You may want to try using a spray can of carburetor cleaner to backflush the two idle air bleeds (one small and one tiny) that face the sky; you can see them on the front wall of the carb throat once you remove the air cleaner.
Author:  SL6 CHILE [ Sat Dec 26, 2009 6:37 am ]
Thanks Dan. The idle system has a idle well (i saw in the pdf and in the carburetor) and in my carburetor he moves to top and bottom. is normal ?? Sorry for my inglish
Author:  SlantSixDan [ Sat Dec 26, 2009 8:31 am ]
I'm not sure what part you mean by "idle well". Can you show us in one of the pictures?
Author:  SL6 CHILE [ Sat Dec 26, 2009 8:38 am ]
Dan the part is a brass tube on the galosine pass to the main jet to idle system.
Author:  Aggressive Ted [ Sat Dec 26, 2009 9:38 am ]
SL6 CHILE,
On page 13 of the 1920 manual, figure 6 shows a picture of the idle well. You can pull the screws holding the economizer body (see figure 8a) in place and clean out the passage way with a piece of 10 to 12 pound nylon fishing line and blow it out with carb cleaner. If that doesn't work and you hit a some blockage use a guitar string. That should clear up your problem.
Author:  SlantSixDan [ Sat Dec 26, 2009 10:29 am ]
That brass tube should not move. It should be solidly fixed in place.
Author:  SL6 CHILE [ Sat Dec 26, 2009 10:53 am ]
Hi guys, good news! I clean the economizer body and the slant works perfect. Thanks for your help. Greetings from Chile
