It is currently Tue Nov 18, 2025 4:39 am
 Post subject: Dutra Duals? *PIC*
PostPosted: Mon Jul 08, 2002 6:42 am
Dr Dodge -
I just scored a Lynx single carb side draft manifold for my 65 Dart GT. I'm going to use a dellorto 40DHLA carb and I'm thinking about cutting the heat riser out of an extra stock manifold I have lying around and making a set of "headers", but I'd be interested in finding out what a set of Dutra Duals would cost, IF you make 'em without the heat riser. Do you make 'em that way, and what does a set cost? And if not, can you give me any pointers on making 'em myself?
Please respond to my email address <A HREF="mailto:mjchael@aol.com">mjchael@aol.com</A> .
thanks,
michael
Mjchael@aol.com
 Post subject: Re: Dutra Duals?
PostPosted: Thu Jul 11, 2002 5:27 pm
: I just scored a Lynx single carb side draft
: manifold for my 65 Dart GT. I'm going to use
: a dellorto 40DHLA carb and I'm thinking
: about cutting the heat riser out of an extra
: stock manifold I have lying around and
: making a set of "headers", but I'd
: be interested in finding out what a set of
: Dutra Duals would cost, IF you make 'em
: without the heat riser. Do you make 'em that
: way, and what does a set cost? And if not,
: can you give me any pointers on making 'em
: myself?
I can do the rear section without the heat box.
This sounds like an interesting set-up, I will drop you some price info.
You can also make your own "custom" manifold(s) by cutting and welding flanges on stock manifold pieces. See the "How to make a rear manifold" in the articles section for the general idea and process.
