| Clifford Hyper Pak with N2O adpater plate https://mail.slantsix.org/forum/viewtopic.php?t=39305 |
| Author: | Joshie225 [ Sun Mar 07, 2010 7:12 pm ] |
| Post subject: | Clifford Hyper Pak with N2O adpater plate |
As it turns out the Super Powershot nitrous plate I drilled to fit my Clifford Ram Flow manifold fits the Clifford Hyper Pak manifold just fine. I'll have to relieve the outer wall of the carb pad a little to clear a path for the outboard spray holes, but that's easy enough. The Valiant should be much quicker this season.
| Author: | speedemon [ Sun Mar 28, 2010 4:59 pm ] |
how much are you going to spray |
| Author: | Joshie225 [ Sun Mar 28, 2010 8:36 pm ] |
Quote: how much are you going to spray
Probably just enough to crack 12s, maybe a little less.
| Author: | DusterIdiot [ Sun Mar 28, 2010 9:01 pm ] |
| Post subject: | Lol... |
Quote: Probably just enough to crack 12s, maybe a little less.
First he has to crack out the die grinder and angle grinder and massage the manifold a bit... -D.Idiot |
| Author: | Joshie225 [ Sun Mar 28, 2010 9:12 pm ] |
Angle grinder? Seriously? Maybe I'll bolt it to the table of my friend's milling machine and relieve the carb pad that way. |
| Author: | ceej [ Mon Mar 29, 2010 6:56 pm ] |
Sounds like a plan to me! CJ |
