| Help! Rear drum brake questions https://mail.slantsix.org/forum/viewtopic.php?t=3931 |
| Author: | Patrick Devlin [ Sat Jul 20, 2002 1:10 pm ] |
| Post subject: | Help! Rear drum brake questions |
Hi everybody, I have an 8 3/4" rear end with small bolt axles that I'm putting in my '68 Dodge Dart. Unfortunately, I don't have the rear drum backing plates for the 10x1 3/4" drums. These seem hard to find around here. Can I use the B/E body 10" rear drums if I also use the B/E body backing plates? Of course, I would have to have the drums re-drilled to 5x4" bolt pattern. I want to keep the small bolt pattern axles, especially since I got new ones. I also don't want to replace all of my wheels, since I finally got ones that I like. Any suggestions on what other rear drums will fit with my axles and the 8 3/4" rear would be appreciated. I already tried drilling the backing plates on my 9" drums, but ran into a snag since the bearings on the 8 3/4" axles won't fit through the centering hole (I don't really want to re-drill this). pwd22@drexel.edu |
| Author: | bud L. [ Sat Jul 20, 2002 4:29 pm ] |
| Post subject: | Re: Help! Rear drum brake questions |
: Hi everybody, : : I have an 8 3/4" rear end with small bolt : axles that I'm putting in my '68 Dodge Dart. : Unfortunately, I don't have the rear drum : backing plates for the 10x1 3/4" drums. : : These seem hard to find around here. Can I use : the B/E body 10" rear drums if I also : use the B/E body backing plates? Of course, : I would have to have the drums re-drilled to : 5x4" bolt pattern. I want to keep the : small bolt pattern axles, especially since I : got new ones. I also don't want to replace : all of my wheels, since I finally got ones : that I like. : : Any suggestions on what other rear drums will : fit with my axles and the 8 3/4" rear : would be appreciated. I already tried : drilling the backing plates on my 9" : drums, but ran into a snag since the : bearings on the 8 3/4" axles won't fit : through the centering hole (I don't really : want to re-drill this). I am not absolutely positive about your idea but I think it might work. I do know that I swapped axles, backing plates and drums(11" x 2 1/2") from a B-body wagon onto an A-body 8 3/4" axle housing. All I remember having to do is shorten and respline the axles and swap emergency cables. fglmopar@aol.com |
| Author: | Patrick Devlin [ Sat Jul 20, 2002 9:14 pm ] |
| Post subject: | Rear brake...found the answer |
Crap! Looks like I'm out of luck with my B-body brake idea. I found the following information on the bigblockdart.com site (also posted elsewhere on the Internet): "Section 2: Flange Axle Taper and Flange Differences Besides the obvious bolt circle lug pattern difference between the A-body 4" BC axle and all other passenger car 4.5" BC axles, there is a sometimes unexpected difference in the flange that tends to cause confusion. The distance from the axle housing flange to the wheel flange of the axle is 1/4" smaller on A-body axles than on the standard 4.5" passenger car axle. On an A-body axle this measures 2", on 4.5" BC axles its 2.25". This slight difference will cause problems when one attempts to adapt brake systems (drum and backing plate together), or a brake drum from a 4.5" BC axle to a 4" BC axle. If you are using original A-body axles, regardless of what BC is may have been redrilled for, you can only use the original 10x1.75" drums (redrill the drums as well)." Man, I wish I ordered different axles, or picked up the backing plates when I was at Carlisle! I'm still asking around locally for 10x1.75" brake backing plates/hardware, but I've had no luck so far. This is getting frustrating, since my Dart is my only car. Quote:
: : I am not absolutely positive about your idea : but I think it might work. I do know that I : swapped axles, backing plates and : drums(11" x 2 1/2") from a B-body : wagon onto an A-body 8 3/4" axle : housing. All I remember having to do is : shorten and respline the axles and swap : emergency cables. pwd22@drexel.edu |
| Author: | bud L. [ Sat Jul 20, 2002 10:36 pm ] |
| Post subject: | Re: Rear brake...found the answer |
: Crap! Looks like I'm out of luck with my B-body : brake idea. I found the following : information on the bigblockdart.com site : (also posted elsewhere on the Internet): : "Section 2: Flange Axle Taper and : Flange Differences : : Besides the obvious bolt circle lug pattern : difference : between the A-body 4" BC axle and all : other passenger : car 4.5" BC axles, there is a sometimes : unexpected : difference in the flange that tends to cause : confusion. : The distance from the axle housing flange to : the wheel : flange of the axle is 1/4" smaller on : A-body axles than : on the standard 4.5" passenger car axle. : On an A-body : axle this measures 2", on 4.5" BC : axles its 2.25". : : This slight difference will cause problems when : one : attempts to adapt brake systems (drum and : backing : plate together), or a brake drum from a : 4.5" BC axle to : a 4" BC axle. If you are using original : A-body axles, : regardless of what BC is may have been : redrilled for, : you can only use the original 10x1.75" : drums (redrill : the drums as well)." : : Man, I wish I ordered different axles, or : picked up the backing plates when I was at : Carlisle! I'm still asking around locally : for 10x1.75" brake backing : plates/hardware, but I've had no luck so : far. This is getting frustrating, since my : Dart is my only car. That's too bad. I was going to suggest you make a 1/4" spacer for the axle bearing retainer, but then you couldn't adjust the end play. You can either go the route I went, or keep looking for 10" SBP backing plates. It may end up being easier just buying a complete axle ass'y. fglmopar@aol.com |
| Author: | Dart270 [ Mon Jul 22, 2002 10:16 am ] |
: That's too bad. I was going to suggest you make : a 1/4" spacer for the axle bearing : retainer, but then you couldn't adjust the : end play. You can either go the route I : went, or keep looking for 10" SBP : backing plates. It may end up being easier : just buying a complete axle ass'y. If you have a little extra bread, you can go to rear discs ($400 w/o park brake, 550-600 with). Check out <A HREF="http://www.tsmmfg.com">www.tsmmfg.com</A>. I have these on my '64 Dart and they are a noticeable step up from 10" drums... Lou |
| Author: | Patrick Devlin [ Mon Jul 22, 2002 4:05 pm ] |
Hey Lou! Thanks for the information. Are the brakes you have on your '64 Dart small bolt pattern? Patrick Devlin Quote:
: : If you have a little extra bread, you can go to : rear discs ($400 w/o park brake, 550-600 : with). Check out <A HREF="http://www.tsmmfg.com">www.tsmmfg.com</A> . I have : these on my '64 Dart and they are a : noticeable step up from 10" drums... : : Lou pwd22@drexel.edu |
| Author: | kesteb [ Mon Jul 22, 2002 5:52 pm ] |
The brake drums and backing plates from a 5x4" 7 1/4" axle with the 10" drums will bolt on. This should widen the search. klesteb@aol.com |
| Author: | Dart270 [ Tue Jul 23, 2002 6:50 am ] |
: Hey Lou! : : Thanks for the information. Are the brakes you : have on your '64 Dart small bolt pattern? : : Patrick Devlin Nope, big bolt. Lou |
