It is currently Tue Nov 18, 2025 6:47 pm
PostPosted: Mon Nov 25, 2002 1:14 pm
Just a reminder guys, we're trying to allow guys to build histories of their cars below. Your comments are welcome, but please drop longer comments / questions in here, rather then in their 'journal' about their vehicle.
Cheers!
Al T
PostPosted: Sun Mar 16, 2003 2:54 pm
Al T
I would like to post some pics of my project but I have them saved on disc,is there an easy way to add them to my post?
PostPosted: Mon Apr 14, 2003 1:55 pm
You can send image files to Chuck or Doug and we can get them up-loaded onto the internet. At that point you can post them here (or anywhere on the web)
 Post subject: photo's
PostPosted: Wed Apr 30, 2003 6:44 am
Doug, can you do that with the picture I sent you of the Scamp?
yes http://www.slantsix.org/photos/mmsc-scamp.jpg
PostPosted: Fri May 02, 2003 2:39 pm
yeah...so now I feel like a jerk. :oops: I should have been paying more attention. Sorry 'bout that. won't happen again.
-josh
64 Dart 170 /6
PostPosted: Fri May 02, 2003 7:36 pm
Bobby,
I will get you Scamp pic up-loaded, no problem.
Josh,
Don't worry about the posting thing, we are trying new stuff here and we are all learning. :)
 Post subject: PlumCrazy71
PostPosted: Tue May 13, 2003 10:01 pm
:D Update.. As the proud Dad (of PlumCrazy71), I thought I'd drop a note here to let you know that his Purple People Eater took 1st place in the /6 class at the Mopar Unlimited NW chapter Spring Roundup! The warmed /6 was a huge hit and the car looks so cool! I know he sincerely thanks all of you for your help during the build. >Thom
 Post subject: Re: PlumCrazy71
PostPosted: Tue May 13, 2003 11:03 pm
Cool,
You got to get a picture of your son next to the car holding that 1st place trophy then add it to your "PPE" post below. :D
 Post subject: Project Duster Update
PostPosted: Tue Dec 30, 2003 10:42 pm
Well Al you asked for an update here it is:
Clifford manifold/headers dropped after headers did not clear steering linkage and I wasn't going to run a stock exhaust. I am running a Super Six setup instead! The car is finally on the ground and man does she llok mean! I used most of the Volare clutch linkage, have to modify one hole on the pivot bolted to the bell housing. I will update webshots when I can
wanderer
Gentry's Garage
LaLa Land in Cali
Looking for 331/354 straight Hilborns for the ol' Hemi!
http://community.webshots.com/user/wanderer64
PostPosted: Mon Oct 08, 2007 4:31 pm
Oops. Sorry! Delete or move my post as you so choose. :oops:
 Post subject: For DusterTeen's Car
PostPosted: Fri Apr 18, 2008 11:55 pm
DusterTeen08,
It looks real nice and clean! If you have a bunch of assembly lube in there, run your cam in, and change the filter. Standard practice anyway. Then stick a Wix on there. Next time you see a Fram, just say, "No thanks, I don't want it to quit!"
If you just rebuilt the engine, that oil change interval should be 100 miles or less. I vote less.
RPM limiting is a good idea when new parts are in use. Wait till the engine is broken in to flail on it. :D A good round number is 1000 miles. I know how hard it is to keep those over-eager tootsies from mashing the throttle. It's all worth it!
Tight tolerances can create a lot of localized heat. Make sure everything is used to it's place and time before standing on the throttle!
If your breaking in, do it on Dinosaur oil, not synthetic or anything with fancy additives. Like GTX or any of the super-slickum in a can crud.
 Post subject: Rotisorre
PostPosted: Mon Mar 08, 2010 2:16 pm
I can't find the thread where the poster had used a sheet of 3/4 inch plywood to build a simple yet highly effective way of rolling his car on it's side. Any help with the thread link would be greatly appreciated
Thanks
PostPosted: Fri Mar 12, 2010 11:41 am
Never mind, I found it.
