Kick down linkage adjustment ?
https://mail.slantsix.org/forum/viewtopic.php?t=3946
Page 1 of 1
Author:  Julia Roth [ Mon Jul 22, 2002 3:19 pm ]
Post subject:  Kick down linkage adjustment ?
A friend of mine and I just installed a Super six setup on my 74 Duster with a Holley 2280 2bbl and Dutra Duals. I am using all the original standard linkage parts for a 2bbl slant six and it all seems to works OK.......
However the transmission does not "kick down" when I push the accelerator peddle to the floor at any speed.
Can anyone give me an idea on how to adjust the "kick down" linkage to get this to work?
Its the standard Torqueflite A-904 transmission.
Thanks
Julia
julie-roth@woz.org
Author:  bud L. [ Mon Jul 22, 2002 4:47 pm ]
Post subject:  Re: Kick down linkage adjustment ?
: A friend of mine and I just installed a Super
: six setup on my 74 Duster with a Holley 2280
: 2bbl and Dutra Duals. I am using all the
: original standard linkage parts for a 2bbl
: slant six and it all seems to works
: OK.......
: However the transmission does not "kick
: down" when I push the accelerator
: peddle to the floor at any speed.
: Can anyone give me an idea on how to adjust the
: "kick down" linkage to get this to
: work?
: Its the standard Torqueflite A-904
: transmission.
: Thanks
: Julia
Though I'am not very familiar with the supersix linkage, if it is like ma mopar's other stuff, it should go like this: with the carb accelerator linkage twisted all the way to wide open throttle(WOT)& the tranny KD linkage pushed all the way toward the back of the car, the rear of the slot of the slotted link(that connects to the throttle stud) should JUST slip over the stud. In other words at carb WOT, the KD should be at the full rearward position. If it is full KD too soon, it will phsically prevent your carb from reaching WOT position.
fglmopar@aol.com
Author:  CRANKSNAPPER [ Fri Nov 01, 2019 3:13 pm ]
DO NOT RELY ON THE 'KICKDOWN' TO DROP A GEAR FOR YOU. REPROGRAM WITH A
MANUAL SHIFT KIT FROM SUPERIOR PRODUCTS AND HAVE AN ALL-MANUAL SHIFT THAT
PERFECTLY TIME THOSE POWERSHOTS.
