It is currently Mon Nov 17, 2025 10:43 am
 Post subject: windage try help
PostPosted: Fri Jul 26, 2002 4:46 pm
I just got the short block back from the machine shop and started to put on my windage tray. I used the ARP studs. The holes in tray had to be opened up to the 1/2" studs. The extra thick nuts ARP uses for these do not let the tray get any closer than 250-300 thou(eyeball). Mike (J&M) recomended 80-100 thou roughly. I hate to take the nuts off and am not sure what to use if I did. Has any one used these studs with the J&M windage tray and how did it work out?
Thanks
Steve
 Post subject: Re: windage try help
PostPosted: Sat Jul 27, 2002 1:44 am
: I just got the short block back from the
: machine shop and started to put on my
: windage tray. I used the ARP studs. The
: holes in tray had to be opened up to the
: 1/2" studs. The extra thick nuts ARP
: uses for these do not let the tray get any
: closer than 250-300 thou(eyeball). Mike
: (J&M) recomended 80-100 thou roughly. I hate
: to take the nuts off and am not sure what to
: use if I did. Has any one used these studs
: with the J&M windage tray and how did it
: work out?
: Thanks
: Steve
I have used these studs without much trouble but I was running a stroker crank.
Sounds like you will need to face some material off the studs / nuts, or bend some dips into the tray's mounting rails.
Users browsing this forum: Bing [Bot] and 67 guests
