It is currently Wed Nov 19, 2025 8:46 pm
 Post subject: my friends cuda
PostPosted: Sat Feb 08, 2003 11:53 am
my friend alos has a 65 and is putting a v8 into it he was wondering if there were any headers that would fit on a 82 318 that would work with a power steering pump, without having to cut stuff up and if he had to cuts stuff up then what type of headers should he get.
if it aint a chrysler it's just fish bait.
PostPosted: Sat Feb 08, 2003 1:41 pm
Choices are pretty limited for the early A. Spitfire comes to mind, but it's a crapshoot as to when you'll get them. However, he does make the only set that don't require cutting out the fenderwells. (I think) Post over on Moparts about Harold/Spitfire, someone will give you his phone number. :shock:
PostPosted: Mon Feb 10, 2003 1:10 pm
If you don't mind paying the coin, the old '68-'69 340 HIPO exhaust manifolds will fit with a little massaging where the coupling collar strikes the right side manifold. The sb magnum manifolds might fit, but you would have to try them on for fit.
