It is currently Tue Nov 18, 2025 5:05 am
PostPosted: Tue Aug 06, 2002 6:19 am
Hi,
I am looking for info as to why the clearence is so large on the most water cooled motors. I now have a 78 LeBaron with a /6 225 motor. Many of my previous cars have been air cooled VW's with valve clearence set to .006 - .008 for both intake and exaust. This is set cold and I never had a burned valve.
Thank you
Paul Bodmer
raven@empire.net
PostPosted: Tue Aug 06, 2002 7:56 pm
: Hi,
: I am looking for info as to why the clearence
: is so large on the most water cooled motors.
: I now have a 78 LeBaron with a /6 225 motor.
: Many of my previous cars have been air
: cooled VW's with valve clearence set to .006
: - .008 for both intake and exaust. This is
: set cold and I never had a burned valve.
: Thank you
: Paul Bodmer
I think it's a little like comparing apples and oranges. In a VW you have an alloy block, cast iron cylinders, alloy heads, and small valves. In an average slant you have a cast iron block(with integral cylinders) and head and really long push rods.
I believe the amount of thermal expansion is dependant upon the change of temperature, the coefficient of expansion of the material, and the size of the material sample.
I don't have my Machinery's Handbook on me right now, but I am pretty sure cast iron 'grows' alot less than aluminum/ magnesium alloy for the same temperature change.
My guess is that when the VW is warming to operating temperature everything alloy grows at such a rate that the (relatively small)cold setting clearances remain adequate even when the engine is hot. What are the clearances when hot?
fglmopar@aol.com
Users browsing this forum: No registered users and 15 guests
