Steering Coupling Shaft Size
https://mail.slantsix.org/forum/viewtopic.php?t=4020
Author:  Ken Sharp [ Thu Aug 08, 2002 5:28 am ]
Post subject:  Steering Coupling Shaft Size
Is the splined shaft for the steering column coupling a different diameter between manual and power steering? I know the power steering shaft is 1" shorter than a manual shaft but is the coupling spline on the box also smaller?
Ken_Sharp@bramco.com
Author:  Doc. [ Thu Aug 08, 2002 3:44 pm ]
Post subject:  Re: Steering Coupling Shaft Size
: Is the splined shaft for the steering column
: coupling a different diameter between manual
: and power steering? I know the power
: steering shaft is 1" shorter than a
: manual shaft but is the coupling spline on
: the box also smaller?
Yes,
The coupling spline is bigger on the manual steering Box. The shafts (power or manual) will accept either coupler.
