| 63 Valiant Antenna Placement https://mail.slantsix.org/forum/viewtopic.php?t=4096 |
| Author: | John Killin [ Thu Aug 29, 2002 2:48 pm ] |
| Post subject: | 63 Valiant Antenna Placement |
This is not an engine question, but I figure someone here might be able to help. I am about to cut the hole to install a factory antenna on my 63 valiant. I am trying to figure out exactly where to cut the hole. I have the factory service manual, but the diagram doesn't match up with the body lines. Does anyone have the correct diagram or have any other tips? Thanks, John Killin Killin5@yahoo.com |
| Author: | bud L. [ Thu Aug 29, 2002 8:32 pm ] |
| Post subject: | Re: 63 Valiant Antenna Placement |
: This is not an engine question, but I figure : someone here might be able to help. : : I am about to cut the hole to install a factory : antenna on my 63 valiant. : : I am trying to figure out exactly where to cut : the hole. I have the factory service manual, : but the diagram doesn't match up with the : body lines. : : Does anyone have the correct diagram or have : any other tips? : : Thanks, : : John Killin I can't tell you about the position, but I can give you a couple of suggestions on how to cut the hole. I don't know what size hole but if it is a 'std'('nice' fraction of an inch)size hole, see if a chassis punch will work. They have a male and female die, which when drawn together by a bolt, makes an exceptionally clean cut. You can get them at HomeDepot, or an electrical supply store. Another alternative is a 'uni-drill', which consists of stepped cone looking drill. They are a little expensive, but they are several drills in one. They, also, make a very clean cut in sheet metal. Those are also available from HoDepot, and asst'd other retail outlets. fglmopar@aol.com |
| Author: | GaryS [ Fri Aug 30, 2002 9:45 am ] |
My '64 manual specifies the location and it should be the same for a '63. The center of the hole is 8-1/64" forward of the door opening and 1-31/32" outboard of the hood opening. lancer_41@excite.com |
| Author: | Bing Kunzig [ Mon Sep 02, 2002 10:23 am ] |
The antenna on my '63 convt. is located on the right rear fender. It was there when I bought the car 8 years ago. Radios were options. Maybe the hole location was too. bingk@webtv.net |
