| torque plate question for Doc https://mail.slantsix.org/forum/viewtopic.php?t=4116 |
| Author: | rustycowl [ Tue Sep 03, 2002 7:48 am ] |
| Post subject: | torque plate question for Doc |
I am ready to finish machine the bore holes in my sl/6 torque plate. Any recommendations for the finish bore size? lanctof@wsdot.wa.gov |
| Author: | Doc. [ Tue Sep 03, 2002 8:54 am ] |
| Post subject: | Re: Torque plate bore size question |
: I am ready to finish machine the bore holes in : my sl/6 torque plate. Any recommendations : for the finish bore size? This really depends on what you will use the plate on. For cast iron SL6 blocks, I would say 3.505 to 3.510 would give you over bore ability into the 3.5 range. (most head gaskets have a 3.5 opening) For the Alm. Block SL6 you need a 3.445 to 3.450 max plate, you just cant bore these engines as far and you need good contact around the tops of the cylinders. DD |
