cams
https://mail.slantsix.org/forum/viewtopic.php?t=4128
Author:  steve [ Thu Sep 05, 2002 6:59 pm ]
Post subject:  cams
Does anyone have any experiece with MP cams? Are they as good as aftermarket? I was looking at the 268 duration and 460 lift. Will an automatic be ok with this and will there be an interference problem with a milled head of .060 to .080? I know this is basic stuff but I've not done a six before. I want something that is streetable (not as a daily driver.) Thanks for the help.
cycledog@iglide.net
Author:  Dart270 [ Fri Sep 06, 2002 5:07 am ]
Post subject:  Re: cams
: Does anyone have any experiece with MP cams?
: Are they as good as aftermarket? I was
: looking at the 268 duration and 460 lift.
: Will an automatic be ok with this and will
: there be an interference problem with a
: milled head of .060 to .080? I know this is
: basic stuff but I've not done a six before.
: I want something that is streetable (not as
: a daily driver.) Thanks for the help.
Steve,
This is certainly a streetable cam. To best use it, you would probably want a higher stall converter (like 2500, which behaves almost like stock). I run a MP 0.490" cam in my daily driver and it works well. It is a bit bumpy, but I can idle it at 6-700 in gear no problem. You won't run into interference problems until you are over 0.600" lift, even with a milled head, so don't worry about that (assuming you have a 225 engine). I have a 0.540" cam in my '64 Dart motor with a 0.120" milled head and there is plenty of clearance.
Author:  james longhurst [ Fri Sep 06, 2002 7:32 am ]
: Steve,
: This is certainly a streetable cam. To best use
: it, you would probably want a higher stall
: converter (like 2500, which behaves almost
: like stock). I run a MP 0.490" cam in
: my daily driver and it works well. It is a
: bit bumpy, but I can idle it at 6-700 in
: gear no problem. You won't run into
: interference problems until you are over
: 0.600" lift, even with a milled head,
: so don't worry about that (assuming you have
: a 225 engine). I have a 0.540" cam in
: my '64 Dart motor with a 0.120" milled
: head and there is plenty of clearance.
: Lou
yeah, i ve run that cam with .090 milled from my 225's head and it worked fine. i used the sliced clay method to check clearance and found a bunch (like .080 or .090".) i'm with lou on the converter. i currently run this cam in my 170 with a milled head and mp valves and it doesn't like the stock converter. i've been too lazy/cheap to rip it out and get it modified like dennis said.
-james
ludite13@cs.com
