'66 Valiant - $? Collector for Duals-?
https://mail.slantsix.org/forum/viewtopic.php?t=4129
Author:  WhaleMstr [ Fri Sep 06, 2002 11:58 am ]
Post subject:  '66 Valiant - $? Collector for Duals-?
Howdy all,
First, do you think $500 for a daily driving '66 Valiant is a good price? LOL (It's not a $200 non-running one!!) Going to look at it today and I will let you know what model and what condition it's in later.
Second, what collector do ya use on homemade "Dutra Dual"? I am slowley starting to work on a set and was wondering where to get one and what to use?
Thanks for any and all opinions!
Later,
Dan
gramma@dm-tech.net
Author:  Doc. [ Fri Sep 06, 2002 12:46 pm ]
Post subject:  Re: '66 Valiant - $? Collector for Duals-? *PIC*
: What collector do ya use on homemade
: "Dutra Dual"? I am slowley
: starting to work on a set and was wondering
: where to get one and what to use?
: Thanks for any and all opinions!
: Later,
: Dan
Flowmaster makes a nice "Y-Pipe" collector, order through Summit for a bit over $30.00 or just weld-up your own, I use pieces of old driveshaft tube as "raw materials".
Author:  WhaleMstr [ Fri Sep 06, 2002 12:52 pm ]
Doc, that is a nice looking unit, but I screwed up. What I was looking for is the piece that actually gets welded to the front "dual" to bolt the collector to? Sorry for being a bit goofy!
Thanks,
Dan
Author:  Doc. [ Fri Sep 06, 2002 5:31 pm ]
: Doc, that is a nice looking unit, but I screwed
: up. What I was looking for is the piece
: (outlet flange) that gets welded to the front
: "dual" to bolt the collector to?
: Sorry for being a bit goofy!
: Thanks,
: Dan
For "homemade" front sections (or special rear sections) I use the stock cast iron factory outlet, (2 inch opening) cut from the stock manifold, relocated and welded onto the new location.
Cut & Welded Exhaust Manifolds
Author:  WhaleMstr [ Fri Sep 06, 2002 7:08 pm ]
Post subject:  Thanks Doc - NM *NM*
Author:  Red [ Sat Sep 07, 2002 6:56 pm ]
: For "homemade" front sections (or
: special rear sections) I use the stock cast
: iron factory outlet, (2 inch opening) cut
: from the stock manifold, relocated and
: welded onto the new location.
: DD
Doc,
Have you tried the Lynx DCOE intake in the PIC? I've heard they don't work all that well, but would be curious to hear about your experience with it.
---Red
