| 73' swinger https://mail.slantsix.org/forum/viewtopic.php?t=4143 |
| Author: | matt gholson [ Sun Sep 08, 2002 6:58 pm ] |
| Post subject: | 73' swinger |
ignition starter screwed up ,has been hot wired ,need wiring diagram ,and how do i put the key switch back in ,as it is im hopping a yellow and red wire under dash while a jumper wire is coming off of battery to kill it i have to pull battery wire , HHHHelp I need to fix it before i sell it, gholsonfour@msn.com |
| Author: | Doc. [ Mon Sep 09, 2002 9:53 am ] |
| Post subject: | Re: 73' Swinger Wiring Problem |
: ignition starter screwed up ,has been hot wired : ,need wiring diagram ,and how do i put the : key switch back in ,as it is im hopping a : yellow and red wire under dash while a : jumper wire is coming off of battery to kill : it i have to pull battery wire , HHHHelp I : need to fix it before i sell it, Most likley a starter relay or a bad nutural safty switch, runs some tests with a jumper wire or test light. I will see if I have the schmatic, here is a link to an earler Darts under dash wiring. DD 64 Dart Under Dash Wiring |
