It is currently Wed Nov 19, 2025 1:56 am
PostPosted: Tue Sep 24, 2002 6:35 pm
When I took my pulley/damper off I did not have a retaining bolt to unscrew. My slant six engine book refers to removing a retaining bolt prior to the removal of the damper.
Can anyone tell me if I am supposed to have a retaining bolt to screw to the front of the crankshaft where the damper is located. I cannot see how it would work to hold it in place even if I had one.
Please advise me with my stupid engine bolt question.
lasergame@prodigy.net
PostPosted: Tue Sep 24, 2002 6:44 pm
Nevermind. I should have read the previous post.
PostPosted: Tue Sep 24, 2002 10:14 pm
: Nevermind. I should have read the previous
: post.
Yes, most all Slants had a "press-on" vibration damper. Some real late engines had a bolt.
Nice that all the cranks are tapped with a 3/4-16 thread so you can add a bolt if you want to.
(although I have never had a damper come-off the crank, I have had the outer ring come off the damper's hub, now that makes some noise!)
Users browsing this forum: Bing [Bot] and 10 guests
