| Motor Mount Bolt Problem https://mail.slantsix.org/forum/viewtopic.php?t=4270 |
| Author: | XMAN [ Mon Oct 07, 2002 3:28 pm ] |
| Post subject: | Motor Mount Bolt Problem |
Anyone have a problem with the motor mount bolt comming loose? This is the 1/2" nut with affixed cupped washer that holds the mount to the K Frame. Twice I've had the LH one come loose and once on the RH side. New mounts torked to spec both times. Any suggestions? usclstaffingnet@sprintmail.com |
| Author: | GaryS [ Mon Oct 07, 2002 7:40 pm ] |
| Post subject: | Re: Motor Mount Bolt Problem |
: Anyone have a problem with the motor mount bolt : comming loose? This is the 1/2" nut : with affixed cupped washer that holds the : mount to the K Frame. Twice I've had the LH : one come loose and once on the RH side. New : mounts torked to spec both times. Any : suggestions? Get a nut with a nylon lock. lancer_41@excite.com |
| Author: | Doc. [ Tue Oct 08, 2002 9:00 am ] |
: Anyone have a problem with the motor mount bolt : comming loose? This is the 1/2" nut : with affixed cupped washer that holds the : mount to the K Frame. Twice I've had the LH : one come loose and once on the RH side. New : mounts torked to spec both times. Any : suggestions? I never had this problem, It could be that the threads are worn, you my want to try som different nuts with some lock-tight. DD |
