| cam selection for /6 turbo motor https://mail.slantsix.org/forum/viewtopic.php?t=42808 |
Page 1 of 2 |
| Author: | Turbo Toad [ Tue Dec 07, 2010 5:25 pm ] |
| Post subject: | cam selection for /6 turbo motor |
Hay guys and girls I need some help in selecting a good cam for a turbo build 1. the car is a 62 valiant 2. 833 OD trans 3. 8 3/4 rear 2.76 or 3.23 sure grip 4. over sized valves with 340 springs ported and polished head 5. Clifford four barrel intake with a 650 holley dp carb set up for blow thru 6. stock bottom end till I can see some results:) 7. Haven't upgraded the oil system yet but its on the list 8. the turbo I got is a garrett gt3271 9. msd ignition 6al with btm control 10. I plan on building my own header but I may just alter a stock manifold please let me no all the help is much appreciative Aaron |
| Author: | VG-265 [ Tue Dec 07, 2010 11:55 pm ] |
I would try it with a stock cam for a start. |
| Author: | Shaker223 [ Wed Dec 08, 2010 4:33 am ] |
went 11.70's @ over 116mph with a stock cam. |
| Author: | Turbo Toad [ Wed Dec 08, 2010 12:43 pm ] |
Hay shaker223 good to see u on /6.org too. So I should beAble to run a stock motor with a good ported head and put out some good numbers? Aaron Shaker what track do u run at. I live in Mich to in the Jackson area |
| Author: | turbo66valiant [ Wed Dec 08, 2010 2:23 pm ] |
I got a .465 lift 220* at .050 cam. How fast do you want to go? You gotta pull the head to change cams so you might want to go with a bigger custom right away. Custom Erson cams are reasonable. I may go bigger this year to make sure I reach my goals. Later Ryan |
| Author: | Turbo Toad [ Wed Dec 08, 2010 5:06 pm ] |
Ryan what's up. My goal is high tens low elevens. If I go with a upgraded cam should I also change lifters as well? Also should I look into arp bolts for the internal components,is there a complete kit of do I have to buy the sets individualy? Also I read a lot about copper head gasket where do I find one of those? Lastly who makes a good gasket kit for the /6 Thanks Aaron |
| Author: | Shaker223 [ Wed Dec 08, 2010 6:34 pm ] |
I usually run at Lapper dragway. Hussy copper will make you a head gasket just about any thickness you want. Seach the site. There was a group buy here last year. |
| Author: | emsvitil [ Wed Dec 08, 2010 7:27 pm ] |
Quote: If I go with a upgraded cam should I also change lifters as well?
You should always change the lifters with the cam.Thanks Aaron After breakin, each lobe and lifter becomes a matched set. So if you ever remove the cam and lifters, remember which lifter goes with which lobe. |
| Author: | turbo66valiant [ Thu Dec 09, 2010 10:18 am ] |
Say, I have the .046 Hussey copper and a felpro set. make sure you get the intake gasket from 66aCuda. Shaker would know if there is another set of head bolt available. I think there was about 7 custom sets made at the higher 220,000 psi? I didn't know there was a group buy on the copper sets. I paid around $80 each. Later |
| Author: | Shaker223 [ Thu Dec 09, 2010 12:57 pm ] |
Quote: Say, I have the .046 Hussey copper and a felpro set. make sure you get the intake gasket from 66aCuda. Shaker would know if there is another set of head bolt available. I think there was about 7 custom sets made at the higher 220,000 psi? I didn't know there was a group buy on the copper sets. I paid around $80 each. Later
$80 is what I paid for my gasket....66aCuda has the spare set of head studs. Check to see if he is willing to part!!!
| Author: | Turbo Toad [ Thu Dec 09, 2010 5:39 pm ] |
Quote: Quote: Say, I have the .046 Hussey copper and a felpro set. make sure you get the intake gasket from 66aCuda. Shaker would know if there is another set of head bolt available. I think there was about 7 custom sets made at the higher 220,000 psi? I didn't know there was a group buy on the copper sets. I paid around $80 each. Later
$80 is what I paid for my gasket....66aCuda has the spare set of head studs. Check to see if he is willing to part!!!Also I was looking in hussey catalog and I didn't see the /6 mentioned in the catalog? Aaron |
| Author: | Shaker223 [ Thu Dec 09, 2010 6:35 pm ] |
You need to call Hussy. You need to know the gasket thickness you want. Turn around was pretty quick. The block, head or both should be o-ring'd. I did the block only. |
| Author: | Turbo Toad [ Fri Dec 10, 2010 2:27 pm ] |
I got a hold of 66acuda and got a intake gasket no luck on the arp head bolts Aaron |
| Author: | turbo66valiant [ Fri Dec 10, 2010 3:55 pm ] |
O-ring the block ![]()
| Author: | Shaker223 [ Fri Dec 10, 2010 4:42 pm ] |
yup!! http://www.flickr.com/photos/18510442@N ... 979/"><img src="http://farm4.static.flickr.com/3064/230 ... 5c485e.jpg" width="400" height="300" alt="Oring" /></a> |
| Page 1 of 2 | All times are UTC-08:00 |
