battery cable
https://mail.slantsix.org/forum/viewtopic.php?t=4437
Author:  elvez [ Mon Nov 11, 2002 5:01 am ]
Post subject:  battery cable
the battery (pos) cable on my wife's 74 swinger/6 is bundled with the wire for the starter solnoid. where can i get a new one? or what is the preffered method of replacement.
thanks
Author:  elvez [ Tue Nov 12, 2002 8:05 am ]
Wow, no-one knows this? what do ya'lls guys positive cables look like?
Author:  Charrlie_S [ Tue Nov 12, 2002 8:18 am ]
I think you can get the battery cable, with the smaller wire from one of the better parts stores: ei: NAPA, Carquest, etc. Two other options are, get a cable wich has a small "pigtail" and butt splice your wire onto the pigtail, or Put a ring terminal on your small wire, put it under the nut for the clamp bolt. The first method is prefered. :)
Author:  Doc [ Tue Nov 12, 2002 8:55 am ]
Post subject:  Battery Cable Info.
Seems to me that most auto parts stores have these.
They do not look like the OEM cable but will do the job.
Many time I can save an OEM cable just by splicing-on a new terminal end, the auto parts stores have a lot of this stuff.
If the at stock cable is completely shot, you can split the harness and reuse the smaller wire with the new cable.
I bet if you really search around, someone out there has an NOS or Repop replacement cable close to the factory part.
Author:  elvez [ Wed Nov 13, 2002 4:34 am ]
thanks, i went ahead and put on a new terminal but that looked like it was gonna be the last time lengthwise. I tried all but Napa. will go there next.
