It is currently Wed Nov 19, 2025 2:18 am
 Post subject: Mallory Ignition
PostPosted: Tue Nov 26, 2002 3:05 pm
Hi Folks,
I have a mallory dual point distributor that has the unilite electronic ignition conversion installed in it. I would like to install it in my car but just want to verify a couple things before I start cutting wires!
Please let me say first I am an electronic moron! enough said!! I know you all can help.
This set-up is all contained within the distributor and only has 3 wires.
Red wire - To positive side of coil / ( I'm assuming I still need the
the wire coming from the ballast resistor to the + side
as well ?? )
Green Wire- To negative side of coil
Black - To a good ground
Is this all I need to hook up? Of course I'm planning on a new high performance coil to go along with this.
Is anyone else using this setup? Any problems?
 Post subject: mallory
PostPosted: Tue Nov 26, 2002 5:49 pm
If you have any questions at all, I'd check with Mallory themselves. Those unilite parts are too expensive to gamble with!
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Tue Nov 26, 2002 7:36 pm
I agree with Bud. I'm sure Mallory must has an application note for the installation. If you take someone's advice on this it would be a gamble.
