| piston options for a turbo'd 170 https://mail.slantsix.org/forum/viewtopic.php?t=4561 |
| Author: | valiant convert [ Sun Dec 01, 2002 7:27 am ] |
| Post subject: | piston options for a turbo'd 170 |
guys, i have a 170 that i am thinking about turbocharging. I also have a turbo from a mitsubishi 2.5. do i have a piston option with the 170 motor? would the 2.2 pistons work in this application?? also, wouldnt the smaller motor be more responsive to the smaller turbos that are so readily avalable? |
| Author: | Al T [ Sun Dec 01, 2002 9:52 am ] |
| Post subject: | Responsiveness of turbo |
In theory it should. . . similar turbo output, less displacement to fill with charged air. |
| Author: | Matt Cramer [ Sun Dec 01, 2002 12:15 pm ] |
| Post subject: | Pistons |
You're going to have very low compression if you just put in a set of 2.2 Turbo pistons into a 170. They drop the compression to unacceptably low levels on a 225 if you don't put in 198 rods, and it'd be worse (I'm guessing around 6:1) on a 170. |
| Author: | 87Slant_sickness [ Sun Dec 01, 2002 6:19 pm ] |
Muhahahaha!! IMAGINE THE BOOST PRESSURE Justin |
| Author: | Patrick Devlin [ Sun Dec 01, 2002 7:57 pm ] |
| Post subject: | Cr |
Hey Matt, What does the CR work out to be when using 2.2 pistons with the 225 rods/crank? Anywhere near 7.5:1? I tried calculating it before, but I wasn't sure about my numbers. If it's near 7.5:1, I might be crazy enough to try it on the street. |
| Author: | Dart270 [ Mon Dec 02, 2002 5:37 am ] |
| Post subject: | another option |
If you were to use 2.2 pistons on stock 225 or 170 rods, you could gain back your compression by milling off about 0.110 from the block and 0.110 from the head (I don't remember exact comp height difference, but this is very close). These are both doable numbers and not difficult to have done. You can also, then, chose your compression ratio at will. Lou |
| Author: | Jopapa [ Mon Dec 02, 2002 4:33 pm ] |
Now I thought you WANTED lower compression pistons if you ran a turbo. Am I wrong here? What's the optimal CR for turbo-ing a 225? |
| Author: | Bob D [ Mon Dec 02, 2002 6:30 pm ] |
Lower compression with a turbo will minimize your chance of detonation but will kill your low end acceleration. I would go with stock compression and control detonation with octane and ignition timing. Bob D |
| Author: | Jopapa [ Mon Dec 02, 2002 8:49 pm ] |
Quote: Lower compression with a turbo will minimize your chance of detonation but will kill your low end acceleration. I would go with stock compression and control detonation with octane and ignition timing.
Cool. Now I don't have to buy new pistons :p
Bob D |
