It is currently Tue Nov 18, 2025 12:17 pm
 Post subject: what to look for
PostPosted: Fri Nov 22, 2002 12:34 pm
on wheel bearings? the brake pads need to be done and the rotors need to be turned and im wondering if i need to change the bearings. lots of grease, they spin nice and everything is shiny. is this a might as well item or can i just repack and go?
 Post subject: Wheel Bearings
PostPosted: Fri Nov 22, 2002 1:53 pm
No pitting or heat discoloration, spins real smooth.....I would repack and go.
Always check to be sure the race is held firm in the rotor or hub, the race will sometimes spin in the hub and cause problems.
PostPosted: Mon Nov 25, 2002 5:28 am
Thank you Doc.
everything went back toghther nicely, suprising how thick those new pads are!.
63 dart vert /6
73 swinger /6
88 ramcharger318 tbi
waiting for something w/a big block
