It is currently Thu Nov 20, 2025 1:30 am
 Post subject: Smoked a piston
PostPosted: Wed Jul 27, 2011 12:19 pm
Smoked number 4 piston, at elk creek. When I got home I drained the fuel tank of race gas, as the car will have to sit for a couple of months. I think I may have found the reason for the failure. To drain the fuel, I disconnected the fuel line from the nitrous system, and put it into a "jug", turned on the fuel pump. The fuel comming out of the line is very airated. I think I am sucking air somewhere between the tank pickup, and the inlet of the fuel pump. This would show as still haveing good fuel pressure, but would cause the nitrous system to run lean. Will look further in the next couple of days.
PostPosted: Wed Jul 27, 2011 2:08 pm
Bummer. And interesting... I guess lean also = fast.
PostPosted: Wed Jul 27, 2011 2:23 pm
I hate it when that happens...
So now... when someone asks: "what are you smoking?" you can honestly answer back: "pistons!" :wink: :lol:
PostPosted: Wed Jul 27, 2011 5:47 pm
Did it burn a hole in it or break out the ring lands?
Yes, lean is mean, right up until it breaks. :shock:
PostPosted: Thu Jul 28, 2011 8:21 am
Looked at it this morning. The rubber line between the tank and the filter (before the pumps) is shot. It actually has the fabric showing.
Dennis, I don't know exactly what it did to the piston. Won't have a chance to pull the engine apart, for at least a few weeks. Have to get my 66 Valiant ready for Knoxville, first.
This car is right at the B/C nitrous weight break. I'll try for another record, up there.
PostPosted: Thu Jul 28, 2011 4:10 pm
care for a hand ?? or 2 lol ??
-Mike
PostPosted: Sat Jul 30, 2011 9:08 am
Elk Creek VA? Thats my local.......
PostPosted: Sun Jul 31, 2011 7:43 pm
that motor ran good @ Mason-Dixon !
slant six's RULE!
http://www.usajon.com
