max BAR on a supercharged 225?
https://mail.slantsix.org/forum/viewtopic.php?t=45895
Author:  USAJon [ Tue Aug 09, 2011 2:51 pm ]
Post subject:  max BAR on a supercharged 225?
does anyone know the max BAR on a supercharged slant six
assuming motor is ready for it.
thanks!
Author:  Shaker223 [ Tue Aug 09, 2011 6:12 pm ]
Ran 20 - 30 psi (turbo) on a stock short block until a piston finally failed. 3000+ beat street miles and over 30 full throttle track passes.
Author:  Dart270 [ Wed Aug 10, 2011 5:46 am ]
1 bar = 15 psi = 1 atmosphere (approximately).
To be more precise: 1.00 bar = 14.5 psi = 0.987 atm.
Shaker has run up to 30 psi boost, which is 2 bar (boosted) above atmospheric pressure (atmos press = 1 bar).
So, the total pressure in his intake tract is a maximum of 45 psi or 3 bar.
For anyone running a MAP sensor, you would need at least a 3 bar MAP sensor to run 30 psi boost reliably. I have 2.5 bar MAPs in my MSI controllers, so I can run up to 22 psi boost reliably.
Not sure if this is what you were asking, but there it is...
Author:  USAJon [ Wed Aug 10, 2011 7:00 am ]
yea i did the math just had'nt posted as yet.
superchargers seem to be rated using BAR...
just asking if anyone had run some big #'s BAR
