Heater Delete
https://mail.slantsix.org/forum/viewtopic.php?t=45978
Author:  raPoM [ Tue Aug 16, 2011 9:45 am ]
Post subject:  Heater Delete
What are you racers doing with the heater hose outlet/inlet on the water pump when you go heater delete? Anyone using caps? If so what are you using?
Author:  Doc [ Tue Aug 16, 2011 10:05 am ]
I tap the hole and install a pipe plug. (upper pump in the photo below)
Remove the hose bib from the head and put a pipe plug in that also.
Keep the by-pass hose functional.
Author:  raPoM [ Tue Aug 16, 2011 10:08 am ]
Thanks Doc :D Off hand do you know what size pipe plug to use?
Author:  Doc [ Tue Aug 16, 2011 10:23 am ]
Off-hand... 1/4 NPT for the water pump bib.
I use a tapered grinding burr to give the hole a little cone shape before tapping.
Be careful with the die cast aluminum pumps, it is easy to crack / split the bib. (try your tapping process on a junk pump first, to get a good "feel" for it)
Author:  Shaker223 [ Tue Aug 16, 2011 10:46 am ]
Using it to cool my turbo!!!!
Author:  raPoM [ Tue Aug 16, 2011 10:54 am ]
Oooohh! I didnt think about that. I plan on running a turbo,thats a good idea!
