Master cylinder conversion
https://mail.slantsix.org/forum/viewtopic.php?t=4616
Page 1 of 1
Author:  persons [ Tue Dec 10, 2002 8:25 pm ]
Post subject:  Master cylinder conversion
:?: When converting to a late model master cyl. dual reservoir and a adjustable prop. valve
should you run the rear or front line off the master to prop. valve ?
Do you run line out of prop. valve to the T to front lines, or to the rear line? Am I close or way off?
Author:  Matt Cramer [ Sat Dec 14, 2002 7:43 pm ]
Post subject:  prop valves
The valve goes in the line coming out of the front (smaller) reservoir on the master cylinder, which then goes through the stock combo valve and then to the rear axle.
