| Water cooled bearing housing hook up? https://mail.slantsix.org/forum/viewtopic.php?t=46571 |
| Author: | Turbo Toad [ Fri Oct 07, 2011 12:56 am ] |
| Post subject: | Water cooled bearing housing hook up? |
I'm working on a tight fit turbo header with a new turbo that's a water/oil cooled bearing housing and I'm wondering how to hook the water Inlet and return lines up I was thinking I could run the Inlet and return off the water pump lines and bypass the heater core how is everybody else running there lines? Aaron |
| Author: | Dart270 [ Fri Oct 07, 2011 4:02 am ] |
I believe that is how it's done. Could leave htr core in line too as that will do nothing but help cooling. Lou |
| Author: | Turbo Toad [ Wed Oct 12, 2011 7:01 pm ] |
Thanks Lou that's how I thought it was done and I didn't think about running it thru the heater core Thanks Aaron |
| Author: | Matt Cramer [ Thu Oct 13, 2011 8:27 am ] |
Yep, used heater core lines on the Mitsu turbo I used to have. (The GT40 going in there is purely oil cooled.) |
