changing my setup
https://mail.slantsix.org/forum/viewtopic.php?t=46763
Author:  Turbo Toad [ Mon Oct 24, 2011 12:03 am ]
Post subject:  changing my setup
I'm still working on my Turbo 62 valiant /6 that when I started the project I converted the push button 904 to a 833 OD but like all projects I decided to convert back to a 904 with a rev manual valve body and was wondering what size stall converter. This is going to be a full street strip car with some serious strip time
All help is much appreciated
Aaron
Author:  Turbo Toad [ Mon Oct 24, 2011 12:23 am ]
Here's some more info 2.94 sure grip, I plan on shifting at around 5200 rpms
I'm running a Turbo grind cam with around 489 lift with 1.5 ratio but with stock rocker arms I no its actually less lift because of the 1.4 ratio
Aaron
Author:  terrylittlejohn [ Mon Oct 24, 2011 1:50 am ]
what tire are you running?you will need 3000rpm to 3500rpm stall for sure. do you have the low 1st gear set for that 904?
Author:  Turbo Toad [ Mon Oct 24, 2011 2:01 am ]
Im running 275 9" 15" rear tire
I guess I didn't even no there was different 1 St gear set where can I find some info on that
Aaron
Author:  Turbo Toad [ Mon Oct 24, 2011 2:29 am ]
Terry I just did some research and I highly doubt that I have a different gear set it's a standard 904 TF that I'm going to put a Rev manual VB in and let her rip lets just hope she doesn't rip apart
Aaron
Author:  Dart270 [ Mon Oct 24, 2011 11:03 am ]
It really depends on your motor torque. W/o information, I'd say get a strong 9.5" converter built for 3000 stall on a Slant.
Author:  terrylittlejohn [ Mon Oct 24, 2011 3:46 pm ]
if your trans hasn`t been rebuilt lately then it probably doesn`t have the lower gear set . it is an easy swap from any new lockup style 904 /500A trans. it can let you run a taller rear gear and still have a good lower ratio.
Author:  1974duster kev [ Mon Oct 24, 2011 4:39 pm ]
When my car was auto I liked my edge converter could foot brake it between 3000 to 3300 rpm. Drove it everyday to highschool and work and raced all the time at test n tune, doing lots of burnouts leaving car shows.
Kev
Author:  Turbo Toad [ Mon Oct 24, 2011 5:03 pm ]
What diameter torque convertor are u guys running
Author:  terrylittlejohn [ Tue Oct 25, 2011 1:46 am ]
i have a 9.5" built locally in N.S. , it`s a 2.2 k-car torque converter body thats modified to fit 904, it stall 3900rpms.
Author:  bigslant6fan [ Tue Oct 25, 2011 5:56 pm ]
Post subject:  .
It is important to consider what RPM your turbo starts to spool. FWIW I have a turbo action "medium 10 inch" that foot brake stalls at 2,600 RPMs with my 0.460 cam S/6
Author:  Shaker223 [ Tue Oct 25, 2011 7:05 pm ]
I have a 175k stall mopar convertor. It is supposed to stall about 2500rpm bebind a big block. I can make it stall pretty much wherever I want. Foot braking i make it stall about 3400rpm.
Author:  Turbo Toad [ Tue Oct 25, 2011 9:13 pm ]
Thanks shaker did u get the chance to run car this year
Aaron
Author:  Turbo Toad [ Wed Oct 26, 2011 2:23 am ]
not only am I changing my transmission but I'm also in the process of building a Turbo header to accommodate the new Turbo I got turbnetics T4 60-1 .60 are on the cold side. 68 are on the hot side this should get me closer to the HP rating I'm after
Aaron
Author:  Shaker223 [ Wed Oct 26, 2011 5:23 am ]
Aaron
nope.
